![Confused2 :confused2:](./images/smilies/confused2.gif)
Some more problems
Some more problems
I have a 1993 mx-3 gs. the car runs good for about the first 5 minutes, but after it warms up it leans out and just kicks and shakes if I try to give it any throttle. Well I was underneath it today looking around and noticed that my egr valve has been completely bypassed. Also found 2 green wires that had been cut, was wondering if these could maybe go to the EGR or maybe the oil pump? The car ran fine for the first three months I had it, and I was wondering how the last person that had it got it to run with the EGR totally bypassed, and advice would be greatly appreciated! ![Confused2 :confused2:](./images/smilies/confused2.gif)
Re: Some more problems
intake intake intake...
check for cracks in the accordion tube
The EGR is an emmissions requirement. Almost everyone bypasses it when they swap motors, and though it is uncommon for someone to have gone tot he trouble of bypassing in on a stock engine, it is not likely to be causing your problem. The two wires are probably the remnants of one of the EGR valve harness connectors.
Wires-->oil pump?...um...no.
