oil pressure gauge
Posted: April 9th, 2010, 4:55 pm
by pirite
time to flame the noob
1994 MX-3 Base model 1.6L
how do i install an oil pressure gauge????
Re: oil pressure gauge
Posted: April 9th, 2010, 7:07 pm
by RS_OBD'oh_2
did your gauge come with directions?
What type of gauge/sending unit?
Did you try to search?
Posted: April 9th, 2010, 7:14 pm
by pirite
havent purchased a gauge yet, yes i searched. i honestly dont even know where to start.
Posted: April 9th, 2010, 7:22 pm
by RS_OBD'oh_2
when you decide on the gauge there should be instructions. I believe there is some info on this in the worklogs. I know Mike installed one, but not sure if there is a write up on it in his WL. Do you need one? Or are you just looking to add an extra gauge?
Posted: April 9th, 2010, 7:36 pm
by pirite
looking to add an extra gauge and also just making sure my oil pump is working at 100%
Posted: April 9th, 2010, 7:47 pm
by pox
The oil gauge should come with a new electronic pressure sender that you will have to put where the old one was. Its on the back side of the block, close to the firewall.
I got a glowshift oil pressure gauge, the new sender had the same threads so I didnt have to re-tap the hole either. (this is on my bp)
Posted: April 9th, 2010, 7:51 pm
by pirite
pox wrote:The oil gauge should come with a new electronic pressure sender that you will have to put where the old one was. Its on the back side of the block, close to the firewall.
thank you. i was wondering where the sending unit was on the block.
any recommendations on gauges? not looking to spend a whole lot but still looking for decent quality..
Posted: April 9th, 2010, 7:58 pm
by RS_OBD'oh_2
I've yet to hear of a failing oe oil issue. you might be spending $ that you don't need to. But don't let me hold you back. Just don't rush it, get a pod and keep it clean looking. Don't forget to make a worklog.
Posted: April 9th, 2010, 8:01 pm
by pirite
well i wanted to put one in either way.
believe me, it'll be clean. im just not sure where i want it yet.
and a work log will get started.
Posted: April 9th, 2010, 8:09 pm
by RS_OBD'oh_2
sounds good. IIRC Mike went with an autometer, and it came with the correct fittings for our cars. Search around and find something you like. There are many companies that offer a good product. Just keep in mind the pod size vs the gauge size.
Posted: April 9th, 2010, 8:22 pm
by pirite
does anyone happen to know the size for the fitting?
Posted: April 9th, 2010, 8:29 pm
by nos92mx3
IIRC its 1/8" bspt
(british standard pipe thread)
Posted: April 9th, 2010, 8:31 pm
by Mi|<E
nm
Posted: April 9th, 2010, 8:35 pm
by pirite
any websites anyone would recommend going to to look for gauges?
Posted: April 9th, 2010, 8:37 pm
by Mi|<E
Jegs has autometer stuff
http://www.jegs.com/i/Auto+Meter/105/4327/10002/-1
you need electrical, not mechanical
