What do you guys think? I'm in dire need of an ecu and pick n pull has been dry for the last month or so.
I might bite the bullet and buy it. I'm gonna do a little more looking around still.
http://cgi.ebay.ca/KL62-ECU-JDM-KLZE-DO ... 5886744b4c" onclick="window.open(this.href);return false;
KL62 JDM ECU
- Newfie_dan
Re: KL62 JDM ECU
if you are running a klze you can chip an ecu for 40 bucks if you do the work yourself, if they are out then I can check here for you and see what I can dig up for ecus. There are a few mx-3s here in the local yards.
- solo_ryder
Re: KL62 JDM ECU
That wont work. Notice the 4 plugs?
The ONLY ecus that are JDM that will work are kl31/kl36
- Newfie_dan
Re: KL62 JDM ECU
unless he is running an obd2 mx3.
- solo_ryder
Re: KL62 JDM ECU
Is that a USDM ecu then?
If its a Millenia JDM ecu I dont see it working as they ran on a MAF system and probably have a different wiring setup then the JDM MX6 or whatever else that ran a VAF
- atomic froster
Re: KL62 JDM ECU
thats a little sketchy, it claims its actual item in picture and shows 3 ecu's and each is diffrent lol
Re: KL62 JDM ECU
I thought it was also sketchy. THanks for the input, im gonna keep looking around.
