Hi, what is the difference between the instrument cluster of mazda mx3 first and second generation? are the same?
thank you
Instrument cluster
Instrument cluster
93' MX-3 1.8 v6 K8
- umcamara
Re: Instrument cluster
GS should be the same as they both used an electronic speedo I believe. RS will be different between generations since the first gen used a mechanical speedo sensor.
GS and RS are different. Different tachometers, as well, the temp and fuel gauges read in reverse when a GS cluster is used on an RS.
newer gs ones have a low fuel light aswell
- PATDIESEL
my 93 GS has a low fuel light...
