Brakes always on
Mr lahey
Brakes always on
Post by Mr lahey »
So I just changed my front pads and rotors on my 96 gs and took it for a ride and the brakes are on a little bit all the time, i took it for a quick ride around the block and saw smoke coming from my front tires, anyone know how to fix this?
EDIT: I also accidentally hit the brake pedal after getting both calipers on before starting up the car, maybe thats what did it?
umcamara
Re: Brakes always on
Post by umcamara »
Why would it matter if you hit the brake pedal before starting the car??
And how do you know the brakes are being applied? Because of the smoke? Maybe you bent your dust shields and they're rubbing against the rotors?
'98 BMW 328is M-Tech
Feedback Thread
Mr lahey
Post by Mr lahey »
umcamara wrote:Why would it matter if you hit the brake pedal before starting the car??
I dont know I didnt think it would but its the only thing I can think of.
I know the brakes are being applied because when I put the clutch in the car brakes and I can feel the drag and it holds me in place when im stopped. There is no irregular noise and its grabbing pretty good so im quite sure the brakes are being applied
umcamara
Post by umcamara »
Next thing I'd look at is your calipers being seized on the sliders. They should be able to float freely.
Feedback Thread
Tollis
Post by Tollis »
Take the calipers and pads off. Take some fine sandpaper to the sliders then coat them in some good brake lube. Then coat the pins with lube and put em back together sounds like the pads are just seized on the sliders.
Cody
1993 GSZE SE
Ryan
Post by Ryan »
It could be a few things..
The main piston is seized
The A frame is seized (two sliders)
The pads are sticking in their little sliders
You forgot the metal clips that help push the pads away from the disc
As suggested, take some fine sandpaper and have a go at the A frame. If you have a round file, you can work on the inside of those sliders too. Use some SILICONE BASED lubricant on reassembly. Anything else will kill the rubbers and then you'll have a dry and dead caliper real soon.
Mr lahey
Post by Mr lahey »
Ryan wrote:It could be a few things..
You're the one who helped me get the calipers back on, thanks for that :D Not sure if you remember but you told me I had to take half the caliper off to put it back on is that the A frame you are talking about. Sorry for the noob questions im just a tad confused and like to be sure of myself :p
You can try using a C clamp to push the pistons back in then reinstall the caliper and apply the brakes and see if they're still binding. My experience on our cars is you'll have to either rebuild the caliper, get ones from the wreckers and hope they're good or buy new ones. Removing the piston and cleaning the cylinder may work as well. If your tires were smoking Holy Mackeral. Those were really hot brakes, not good.
