idles up and down!
Posted: March 19th, 2010, 2:19 pm
by ROACHE2010
so when i pull up to a light and put it in gear the car idles from about 1500 to 700 rpm...but if i put it in netural it just seems to idle higher than normal but doesnt idle up and down.its really annoying having to keep putting in netural please help!!!
Re: idles up and down!
Posted: March 19th, 2010, 2:32 pm
by Ryan
Details man! ATX? MTX? Year?
INTAKE LEAK!
http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;
Posted: March 19th, 2010, 4:11 pm
by ROACHE2010
92 with the klze swap.
Posted: March 19th, 2010, 8:55 pm
by Bolverk
Mine did the same thing until I replaced the accordian part of the intake tube.
Posted: March 19th, 2010, 9:04 pm
by mikeinaus
mine did that on my old motor. if i lowered the idle a bit it went back to normal. check for vacuum leaks thow... there the most common cause of jumping idle.
Posted: March 19th, 2010, 9:36 pm
by Mooneggs
ensure the TPS is adjusted correctly and you may need to adjust the IAC... if nothing else you can turn your rear defrost on and it should even it out...
Posted: March 19th, 2010, 11:04 pm
by TMP39
try cleaning your iac and check for vacuum leaks. and clean your tb while your at it. those are usually the main three things i find that find cause that problem when a car comes in at work wit hthe same idle up n down problem. kinda gets repetative after a while
