Cyberdyne Temperature Gauge Install.
- jkbreazeale
So, my temperature gauge has died. It really is my fault, I popped the needle off when I took my reverse glow gauges off and it never worked right since. I purchased a Digital Cyberdyne Temperature Gauge to install.
The instructions are pretty straight forward:
Red = Switchable 12v power source (when car is on, it is on, when car is off, it is off)
Black = Ground
White = Wire going to sensor.
I am trying to find the best wire for the switchable wire to go to. I think that the word "switch" has thrown me for a loop. Any suggestions? I plan on installing the gauge pretty much on the cluster in front of the existing temperature gauge for now until I get the rest of my digital set up.
Black = Ground
1993 MX-3 RS (my project car) http://www.cardomain.com/ride/3815854 <- Check out my Cardomain!
1995 MX-3 RS (wife's project car)
- jkbreazeale
Re: Cyberdyne Temperature Gauge Install.
Also... this is for my 93 SOHC. I have removed the original sensor to compare the size and threads to the new unit. Significantly smaller. The Cyberdyne one is 1/8" NPT. What would be the size of the original? Just trying to get some familiar help considering my other option is spending about an hour or so at Lowe's.
- SpatialTerror
well it shouldnt matter which 12v power wire you hook it too. as long as it shuts off when you turn the key to acc and off.
SpatialTerror
SpatialTerror
- jkbreazeale
Well, that's my thoughts on it, but for the life of me, I am having a brain fart or something and cant think of a wire that isn't going to be constantly on. I also ended up removing the wrong sensor. I removed the one off of the thermostat as opposed to the one on the intake manifold. From what I have read, the one on the thermostat gives the reading to the gauge, and the one on the intake manifold is the one that controls the air/fuel ratio. With that being said, can I still use the one that is on the thermostat?
- RS_OBD'oh_2
if you have a multi meter, all you need to do is check one of the red wires. Key in on is 12v/ off 0v. Not much too it. Just make sure to have your other meter lead to gnd.
- SpatialTerror
no you want the wire on the thermostat.
just make sure you have the right one
cuz theres 2 sensors on it
SpatialTerror
SpatialTerror
- jkbreazeale
Those last two posts really helped out. I know it didn't seem that difficult to install but I like to make things more difficult than they really are sometimes.
To recap.
12v when on, 0v when off is what I am looking forward. As mentioned, naturally the ignition wire would work perfectly. I can use the sensor location on the thermostat for my digital gauge sender.
I know that there is alot of confusion because we have a coolant temp sensor on the manifold and a temp sensor(sender?) on the thermostat. I guess as long as the sender is in coolant, it will do it's job. Now, all I need to do is figure out what size thread is on the sensor/sender in the thermostat and get an adapter for my 1/8" NPT.
To recap.
Isn't Cyberdyne the company that created SkyNet? Are you sure it's wise to install that into your car? :p
A self aware MX-3 would be 'The Return of Christine', key the AC/DC music..
- jkbreazeale
... you just had to go there didn't you... I hope you stump your toe!Isn't Cyberdyne the company that created SkyNet? Are you sure it's wise to install that into your car? :p
Anyways, supposedly it's a pretty good gauge company that's been around for a while and just happened to have what I was looking for... except the brass npt fittings that I need to install the damn thing!
- jkbreazeale
Re: Cyberdyne Temperature Gauge Install (Installed!!!).
I finally got the gauge installed. For reference to everybody... do NOT force a 3/8" adapter for 1/8 NPT sending unit into the hole for the stock coolant temperature gauge sender in the thermostat. It will crack the housing. Use a 1/4" and a good bit of threading tape with some sealant around it and it will work just fine.
To wire, I used the +B on the back of the speedometer housing for the hot wire. The ground wire can not be the ground on the back of the speedometer housing. For some reason it is not a good enough ground. Ended up drilling a hole through the firewall and used the grounding bolt on the transmission. The gauge looks and works awesome, I will post a picture tomorrow. Next install will be a Cyberdyne Digital Fuel Gauge.
