Which Throttle Body for KLZE curved neck?
garretc16
Post by garretc16 »
So i have a klz curved neck in my car I am wondering what throttle body should be on it aswell as what intake tube and MAF? Should there be an mx6 throttle body with a k8 intake tube and MAF?
Thanks if you respond would help me out alot
JWMX3
Re: Which Throttle Body for KLZE curved neck?
Post by JWMX3 »
KL47 is the common millenia IM throttle body
KL68 as well.
The VAF depends on which ecu you have to run the motor. You want the stock JE50 VAF if you're using a KL31, KL36 or Probinator-Chipped ECU's
garretc16
Post by garretc16 »
I am running the probinator chipped ecu... so i need to find the throttle body off a millenia and JE50 VAF?
