94 ecu in a 92?
atomic froster
94 ecu in a 92?
Post by atomic froster »
so im trying to get an ecu for my klze, i have a 92 gs, i have heard they require a certain ecu. so with my wtb add johnmx3ze said he has a kl36 ecu that was in a 94 mx3 will that work in my car? if so does anyone know where i can find some sort of explanation on how to swap them out?
Re: 94 ecu in a 92?
As long as it's not OBDII you can swap it in no problem.
Besides, the KL31/KL36 ECU's are OBDI only, so no big deal.
Ideally they do perfer the 92-93's because they have the extra coolant sensor.
johnmx3ze
Re: 94 ecu in a 92?
Post by johnmx3ze »
Nd4SpdSe wrote:As long as it's not OBDII you can swap it in no problem.
so it will fit?
Re: 94 ecu in a 92?
Yes, 100%
