car keeps dying!
Posted: December 23rd, 2009, 7:07 pm
by 96chris
now i have a different problem on my hands. thought the alternator went, so i took it out and got it tested.. it was fine. so then took the battery out and it was too dead to even test if its still good or not. but its only like a year old battery. so i have it on a trickle charge right now, then going to see if it works. it was wierd i was drivin to my buddies place the other night and i was turning a corner and went on the breaks then my radio died? took my foot off then it went back on. did it a few more times then it never came back on. so i got there visited for a bit then went to leave and the battery was stone dead. so i got boosted but would bog right out and not even let me barley on the gas. so made it half way home and it died. got a boost made it further then died. then i made it home. boosted it today let it sit running for awhile but in netural still wouldnt let me on the gas and bad back fire under the hood when i give it lots of gas.. pushed the clutch in and died..
Re: car keeps dying!
Posted: December 24th, 2009, 12:19 am
by Ryan
Sheesh, I dislike how people continue to drive a car that barely runs.
Check the basics. Strong spark? Idle set correctly? Good fuel pressure? VAC LEAKS? Clean up the grounds. Clean up battery terminals. Don't just ignore it.
If you want procedures on how to check all of these... ask nicely, or get a mechanic.
Posted: December 24th, 2009, 11:06 am
by Daninski
Ice in the fuel line.
Posted: December 25th, 2009, 1:54 am
by Ryan
Danny, you must know I hate that argument. Last winter I poured gas and water together in my mother's bakeware and left it outside overnight during the cold snaps.. you know, where your piss freezes before it hits the ground...
#1 the gas and water separate like mad, but according to high school chem, there is always SOME degree of mixing between polar and nonpolar substances.
#2 according to my home-science that doesn't mean the gas freezes. Only the 50/50 mix really made slushie, but if your tank is 50/50, you're not going anywhere, even in summer.
#3 winter gas contains additives to stop this (nonpolar substance, like ethanol, that combines with the water and keeps it from freezing)
I'm dead set against frozen gas lines. I must see the slush come out from the rail before I'll believe it, because the rest of science goes very much against it.
Posted: January 19th, 2010, 11:36 am
by Jwk77
to your power issue you could have a draw on your electrical system why you have a dead bat check your strereo and around your brake pedal and brake light for open wires also the bat could have a bad cell. also most stereos cut out when low on power when your pressing on your brakes your taking power away from it so it could have cut out and low power could mess with computer, fuel press etc
