[WTB] k8 stock log
- pattheriault
[WTB] k8 stock log
I need some K8 stock exhaust manifold.
might be able to trade for my SS autochrome headers.
let me know if you have some
Re: [WTB] k8 stock log
I have both but the rear manifold has a rusted out egr tube nut that's stuck in it. Lemme know if ur interested.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
- pattheriault
can you show me a pic.. im not sure of what you mean..
I never had the stock log when I bought my car so.. and how much would you want?
I'll try and get some pics soon, but they are stock exhaust manifolds, no collector pipe or anything. I would say 10 plus ship for both. Where are you located?
Also, how come you dont want your autochromes? Are they turbo pipes? Just curious.
- pattheriault
Im in new brunswick Canada..
E1C 3R1.
I dont need the collector.. and I need the stock log for my turbo pipe.. I bought rebel2k4 set up and he was running his pipe from the k8 exhaust mani.
E1C 3R1.
I have 1996 manifolds with a O2 sensor hole in them if your stuck. The 96's are a little longer. One way or the other enjoy your build. Cheers.
- pattheriault
96 wouldn't workif they are longer.. my pipe would be too low.
but thanks anyway
but thanks anyway
short4stuff
Are 94 probe gt logs the same?
- pattheriault
im not sure.. but i would say probably not since they are for the 2.5 and not the 1.8l.
- pattheriault
- solo_ryder
KLDE primaries will work, but the secondary will be longer. Check the junkers?
- pattheriault
- solo_ryder
Primaries are the part that bolts onto the heads, secondary is the Ypipe that connects to it. Oem and aftermarket headers are usually a 2 piece design. A primary and a secondary.
Kdle primaries will work. Why do u want stcok stuff anyways?
The turbo pipes from rebel2k4's setup use the stock manifolds, I have a set $10 plus shipping if your interested PM me. My turbo pipes use the same method.
- pattheriault
I need the stock primaries for my turbo pipe! it's what Rebel2k4 used on his/my now set up.solo_ryder wrote:Primaries are the part that bolts onto the heads, secondary is the Ypipe that connects to it. Oem and aftermarket headers are usually a 2 piece design. A primary and a secondary.
