does anyone know the actualy width or the RS sway bars? autozone says 19mm, advance auto says 21mm and pep boys shows like 30mm!!!
any ideas? i don't have a caliper, otherwise i'd go measure it.
sway bar question
- MapaX5
sway bar question
'91 MX-5 with plenty of mods, '94 DOHC MX-3__HP Design muffler, glasspack, custom intake (superk's idea), KYB GR-2 shocks, projector headlights, GS front end, Rear Disc brake conversion, swaybar and tie bar, and lip spoiler, JDM mazdaspeed full-length side skirts,
Re: sway bar question
It changed from year to year. I believe that the rear was always 18 or 20mm but I can't be sure about that. The front went from 20mm to 22mm in 96' iirc.
This information has been discussed in the past.
- MapaX5
i figured it was, i tried searching for it but couldn't find anything. i was asking so i could get replacements and do them while i do my shocks and then order the ES ones whenever you found that info for me.
thanks again.
thanks again.
Sorry, my desktop PC is really hurtin'. I am having trouble getting it to work and I need it to view the part files I created. I'm working on it.
- MapaX5
it's not rush. i just don't like body roll that's all. lol. the ones on it are WORN. like i can literally move the bar and it's loose in there. so that's why i wanna change them.
- MapaX5
ok, so the struts are replaced! car feels like a new car, holy jeez! lol.
still want those ES sway bar bushings, but no pressure. lol. thanks again for your info/time.
The drawings I made of the SuperPro bushings that were in the kit I had were for a 20mm rear bar and a 22.8mm front bar. I know that I looked at the ES stuff once and the problem I found was that even with an ES bushing of the correct ID the stock clamps are not the right size to hold the bushing. You would have to find a way to secure the ES clamps to the chassis.
