Klde turbo how much boost?
Djdaveflow1
Post by Djdaveflow1 »
How much boost can i put on my klde stock internal with my t3/t4E (57 trims) ? With megasquirt management
Can I put kl31 cam only on exhaust because i got only this camshaft for upgrade
Do it work?
Can I use the curve neck intake on kl-01 head?
mx3autozam
Re: Klde turbo how much boost?
Post by mx3autozam »
If your going to be playing with cam like this then swap out the klde intake ones for the ze ones. That will benefit ya with boost.
As for what the motor can take. Its all in the tune man. You should also not be worried how much boost the motor will take. Its about the power. Thats what breaks things. A De will make over 300whp on probably 10psi with proper tuning and a good setup. You should look on Probetalk there is alot more info on there!
93 Mazda MX3 KLZE Turbo
Return to “Forced Induction”
