what clutch do i order
TMP39
Post by TMP39 »
ok i've googled, searched, and pretty much everything i can think of but still dont no why i cant find it. but i need to know what clutch should i order for the ze i have. i bought hte car with it in it got it runnis, it runs awesome, but i dont no what trans it is yet but does it matter if i ordered an mx6 clutch kit or mx3 one when i pull it for the swap? can someone give me a litle headway on this. and if ure wondering i was looking to get the spec stage 1
hgallegos915
Re: what clutch do i order
Post by hgallegos915 »
mx3, probe gt, mx6 cluches all fit. I recommend probe gt or mx6 as they are a bit larger.
Ebay clutches are good for stock ze. f1 gripforce and so on. You dont really need an over the limit expensive clutch for an n/a stock ze. Unless you are building it, nitrous or boost.
-hec
cyberhi07
Post by cyberhi07 »
So would this type of clutch work out well?
http://cgi.ebay.com/ebaymotors/XTD-STAG ... ccessories" onclick="window.open(this.href);return false;
Im kinda in the same boat right now and i have been looking at this since i wont be doing much to the engine but a few bolt on's.
2fazed
Post by 2fazed »
Get an Exedy clutch. Most of those Ebay clutches won't last.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Return to “Transmissions”
