BP questions
nos92mx3
BP questions
Post by nos92mx3 »
Yes i have migrated from the b6 to the bp side.
I bought smoke's mx3 and am currently going thru it.
A few questions
What are the factory bp injectors rated at (cc wise) also a part number would help.
What is the bp ecu's rev limit. I could have sworn ive seen the tach go to 7800 more than once. Though the stock tach can probably be off isnt the revlimit 7400?
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
Mi|<E
Re: BP questions
Post by Mi|<E »
BP is between 230 and 240 cc stock injectors, there is some debate on this.
part number is: #195500-2180 for the tan top.
and they are listed at 265cc on the denso site so go figure.
The blue top mx-3 injectors are 230 cc
bp ecu rev limit is 7200 rpm
Here is a good read on injectors:
http://www.miataturbo.net/forum/t4288/
nos92mx3
Re: BP questions
Post by nos92mx3 »
I figured they would be between 230-240 and i do have the tan top injectors installed.
For some reason this thing idles pig rich, were talking 11-1, so i played around with the maf and now we are idleing at a nice 15-1.
I originally thought that the intank walbro was overpowering the stock fpr, so i swapped it out with an adjustable one, no change.
Any chance the factory ecu has been modified? for fuel and or rev limit? I didnt think we could mod our ecu's.
Its a bp with a gtx intake manifold with an intake, and exhaust.
Nothing spectacular, but when i averaged 20 mpg i was a bit leery.
93' Rs-t BPT - Sold
Mi|<E
Re: BP questions
Post by Mi|<E »
Im not sure what your running, if it is what you have in your
sig or not, but leaning out past 14 isnt a good idea.
The BP26 Ecu cant be easily or readily modded on its own so
assume for now its stock.
So your using a BP26 ecu with the tan top injectors and no turbo?
This would be why its running so rich. If there is no turbo in your
setup grab a BP09 / BP10 ecu.
list more details for me
nos92mx3
Re: BP questions
Post by nos92mx3 »
whoops i need to change my sig.
That was my old mx3 i recently got a new one.
The new one is a bp with gtx intake manifold, with an intake and exhaust.
Ive got it running nice now i just had to do some tuning. :D
turns out it was also running 0* ignition advance :shock: , so i bumped that up to 12* and all is well.
93' Rs-t BPT - Sold
Limegreen mx-3
Re: BP questions
Post by Limegreen mx-3 »
nos92mx3 wrote:whoops i need to change my sig.
U mean tune up.
nos92mx3
Re: BP questions
Post by nos92mx3 »
no, tuning.
I had to adjust the vaf, fuel pressure and timing accordingly.
93' Rs-t BPT - Sold
Limegreen mx-3
Re: BP questions
nos92mx3 wrote:no, tuning.
OK
