I have a set of Corksport cams produced by WEB. This are reground using new Mazda cams. I sold my wagon but these were not included in the sale so I need a set of stock turbo cams (BP26) to put in their place.
I put down 190whp on an otherwise stock GTX setup through a stock down pipe with these installed. I was running them with stock cam gears so I'm sure there was a ton of overlap.They really should be installed with adjustable cam gears and dyno tuned to get the most out of them. I will take $250 and a set of stock turbo cams for them. Located in NY 12589.
Here is an exhaust clip with these cams installed.
and a quick pull from inside my wagon with two 200 pound people inside.
and another just because I already miss my wagon.
