b6bf cheap compressor idea
djArias
Post by djArias »
My friend called me and told me that he has got a very cheap compressor from XEDOS 2,3 miller engine, and that as far as his oppinion is concerned it would be easy to install this compressor to mx-3. But I dont know If I understand the Idea of compressor correctly - did I describe everything on the picture correctly (of course the choke will be removed).
Do you think that this is a good idea, and that it is possible to get a Charged Mx-3 for less than 150$?
b6BF 116hP@6431RPM ;>
WhiteFinish
Re: b6bf cheap compressor idea
Post by WhiteFinish »
No, not possible
All the materials etc would be 150+
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Mnemonic
Post by Mnemonic »
it wont be cheap but you could do it :) gonna have to fab a lot of new stuff, 1st would be intake manifold :)
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
djArias
Post by djArias »
I thought connecting compressor is easy - why new intake manifold, many people using CIVIC's just add one of those "jackson racing" compresor kit's which includes - compressor, piping, belt and it works fine...?
93vtecklr
Post by 93vtecklr »
Because Jackson Racing builds bolt on kits designed for the civic, if someone were to build a s/c bolt on kit for the mx3 then id buy it too.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Mnemonic
Post by Mnemonic »
little difference between those JR superchargers and that miller one
93vtecklr
Post by 93vtecklr »
There'd be a lot of development needed to make an IM that will work with stock sensors.
djArias
Post by djArias »
I may be wrong again - but my friend bought an EATON M45 and he used in in his VW PASSAT. As I said I may be wrong but he said he changed completely nothing just welded eaton under the bonnet used couple of old exhaust pipes and everything seems to be working fine - even the DYNO showed proper BHP power....
93vtecklr
Post by 93vtecklr »
Is your car a v6? Doesn't the miller charger have to be mounted above the intake ports? A passat is very different than the mx3.
djArias
Post by djArias »
I have a v4 engine DOHC. I dont know where this compressor is to be installed but looking at it's pictures there are only two holes in it - one goes directly to the engine second to the air filter - which in my opinion makes it a very easy to install and typicall compressor but I'm a little bit affraid that if I'm wrong I may destroy the engine... :twisted:
Ryan
Post by Ryan »
sure man, but you can't just magically fasten it to the motor.
and its an I4, not V4.
djArias
Post by djArias »
I've been thinking about it - MX-3 1.6 did have A/C compressor - so if my car doesn't have it there must be some empty space for such a small air compressor :)
I want to buy A/C COMPRESSOR MOUNTING BRACKET and weld this air compressor to it...
Still there are some doubts concerning where exactly does the A/C compressor go and whether welding is the best idea :)
Superchargers don't use blow off valves...
93vtecklr
Post by 93vtecklr »
I'm drunk right now and read the post about 8 times, maybe i didn't see it, where did he mention a BOV? If he did he should spend the 150 on cab fair. Welding is such a bad idea, get a bracket CNC cut, or water jetted, if you're dumb use a plasma cutter and a drill i don't effing care. Still a bad idea IMHDO (im my humble drunk opinion). If you want to weld a blower to an engine, you need to take the damn bus.
Mx3Kid16
Post by Mx3Kid16 »
Nd4SpdSe wrote:Superchargers don't use blow off valves...
where the flyin *uck did that come from!?
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
Return to “Forced Induction”
