heres a video...
what do you think is ******?
marcdh wrote:Tractor POWA!
Yes, somethings definately banjoed. Rods? Pull the sump off and take a took! UnluckyHow'd it happen?
You probably shouldn't start it anymore to reduce further damage...
the oil in the intake was comment out of the intake not in... all my intercooler piping is 100% without oil... my turbo has no oil in it so... yeah the oil was comming out the intake manifold...nos92mx3 wrote:It looks like that motor was ingesting quite a bit of oil.
and since a motor that burns oil is more prone to knock, id check your turbo seals/crankcase setup.
Well thats when you put the new motor in..
yep im now looking for a klde so if anyone has one pm me...DeepBlueMX3 wrote:Don't worry!this is only a start to a faster and better car...it happens....Better luck w new engine!!!!
yes i know i will rebuild for sure...Daninski wrote:Any DE you find will need to be rebuilt. They had a couple here at the pick and pull for around $450.
