Clutch fluid coming out of clutch pedal...
Posted: August 25th, 2009, 6:44 pm
by jkbreazeale
Yeah.. just as it sounds. It looks like the pipe as soon as it goes into the firewall... looks like a gasket was there once upon a time, now not so much... It is weeping oil... kind of messy. Any ideas? I will try to have some pics up tomorrow if needed.
Re: Clutch fluid coming out of clutch pedal...
Posted: August 25th, 2009, 8:26 pm
by Inodoro Pereyra
Posted: August 25th, 2009, 10:33 pm
by seboroth
I second that notion.
Posted: August 26th, 2009, 5:51 am
by jkbreazeale
How does something like this happen? That way I can make sure it won't happen again.
Posted: August 26th, 2009, 5:56 am
by chrome730
Not really its just old age
Posted: August 26th, 2009, 4:42 pm
by hgallegos915
it has happened to me lol and yup old age is the culprit, or a defective unit.
might as well replace the slave while you are at it, its only like 45 dllrs and that usually lasts less than the master cylinder.
Posted: August 26th, 2009, 6:30 pm
by Inodoro Pereyra
I agree 100%.
JK: if people like you could avoid these things from happening, people like me would be unemployed...
Don't forget to buy brake fluid...
Posted: August 29th, 2009, 4:39 am
by vansolrick
Yeah remember to get brake fluid. Be careful when removing the hydraulic lines, and remember to bleed the lines after you install or rebuild your new master cylinder by using the bleeder valve at the slave cylinder (on tranny).
Re: Clutch fluid coming out of clutch pedal... FIXED!!!
Posted: September 6th, 2009, 10:29 pm
by jkbreazeale
Hooray! I fixed it. I ordered the master cylinder and had it installed within an hour and was back on the road without leaks! Now I can reinstall my carpet... after I get my amp wires ran for the subs
Thanks for all the help!
