Clutch fluid coming out of clutch pedal...
- jkbreazeale
Yeah.. just as it sounds. It looks like the pipe as soon as it goes into the firewall... looks like a gasket was there once upon a time, now not so much... It is weeping oil... kind of messy. Any ideas? I will try to have some pics up tomorrow if needed.
1993 MX-3 RS (my project car) http://www.cardomain.com/ride/3815854 <- Check out my Cardomain!
1995 MX-3 RS (wife's project car)
- Inodoro Pereyra
Re: Clutch fluid coming out of clutch pedal...
Diogenes of Sinope.
Diogenes of Sinope.
I second that notion.
95' Mazda Mx-3
1986 bmw 325e-rust in peace
1996 Subaru Outback-Sold
2002 Bmw 325XIT
2002 Bmw 325XIT
- jkbreazeale
How does something like this happen? That way I can make sure it won't happen again.
Not really its just old age
It only takes a single voice to start a revolution
it has happened to me lol and yup old age is the culprit, or a defective unit.
might as well replace the slave while you are at it, its only like 45 dllrs and that usually lasts less than the master cylinder.
-hec
- Inodoro Pereyra
I agree 100%.
JK: if people like you could avoid these things from happening, people like me would be unemployed...
Don't forget to buy brake fluid...
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
Diogenes of Sinope.
Diogenes of Sinope.
- vansolrick
Yeah remember to get brake fluid. Be careful when removing the hydraulic lines, and remember to bleed the lines after you install or rebuild your new master cylinder by using the bleeder valve at the slave cylinder (on tranny).
- jkbreazeale
Re: Clutch fluid coming out of clutch pedal... FIXED!!!
Hooray! I fixed it. I ordered the master cylinder and had it installed within an hour and was back on the road without leaks! Now I can reinstall my carpet... after I get my amp wires ran for the subs
Thanks for all the help!
