Page 1 of 2
help!!! i have coil overs :P am i doing this right
Posted: August 14th, 2009, 2:48 pm
by cricketol2
this is what i got .. is this right idk please someone help
Re: help!!! i have coil overs :P am i doing this right
Posted: August 14th, 2009, 4:58 pm
by 93vtecklr
Sorry I gotta say it, your bedspread looks like the exterior of a honda. I'm thinking that the second nut should also be threaded up, to lock the other in place.
Posted: August 14th, 2009, 5:06 pm
by cricketol2
but is the coils adjuster in the right place thats what i would like to know
p.s. i dont have the other parts and im not going to take it all apart just to find out that i f*^(ed up ..
Posted: August 14th, 2009, 5:20 pm
by RS_OBD'oh_2
Hold on. I would think that the coils should be sitting damn nearn on the strut. They should come with O-rings that should fit between the coil and the outside dia of the strut. I don't think they fit low enough. Do they come with set screws?
if this is how they are seated and work that way, may not like the ride qualtiy. They look a little cheap with out progressive spring rates.
I say that they don't fit your struts.
Posted: August 14th, 2009, 5:22 pm
by 93vtecklr
How low do you want to go? Are those the ebay coil-overs?
Posted: August 14th, 2009, 5:26 pm
by cricketol2
so they dont fit the strut.. and they came with o-rings but it told me to just put it on the strut.. im now at this.. so idk where in the strut it would go i have a bag full of them..
and for how low they sit idk did not put them on yet.. i dont want to f*&^ sh!~ up so i want to know how to really put them on so i dont brake things
Posted: August 14th, 2009, 5:28 pm
by cricketol2
yes there the ebay coil overs.. they told me that the may fit the tokico hp but i dont know if they do know .. my have to go machine a part to have the coil adjuster more less sit on the spring base what do you think about that ..
Posted: August 14th, 2009, 5:29 pm
by RS_OBD'oh_2
the coil collar should be sitting around the blue section of your struts... I don't think the aluminum collars can handle the wieght of the car and would probably split. There must be lots of play in the collar.
Posted: August 14th, 2009, 7:16 pm
by cricketol2
i was board and tried them on my stock struts and they fit them not the ph..... not to happy /:( well back to the drawing board ... so are lowing springs well not compressed on the strut i got them on ebay as well.. they fit but they are loose on the strut ??
the dropzone are a 1.8 idk what that means? but so you know ..
this is the ebay url
http://cgi.ebay.com/ebaymotors/NEW-Drop ... ccessories" onclick="window.open(this.href);return false;
Posted: August 14th, 2009, 7:28 pm
by RS_OBD'oh_2
pics may help.. But you should need a spring compressor to install lowering springs. I would like to suggest you just get the eibachs.. I've done the same thing you have, just to see things fail.
Posted: August 14th, 2009, 7:43 pm
by cricketol2
if things go any worst i was just going to go with .. theres
http://www.horsepowerfreaks.com/perform ... /Coilovers" onclick="window.open(this.href);return false;
Ground Control Coilovers for the MX3
Posted: August 14th, 2009, 7:51 pm
by RS_OBD'oh_2
they look like they might be drop zones.. they should be fine. Again.. no pregressive spring rates.
Posted: August 14th, 2009, 7:52 pm
by umcamara
You don't need a spring compressor to get the rear springs on the struts, they don't really compress at all. Many people can confirm this.
Posted: August 14th, 2009, 7:54 pm
by cricketol2
ok cool thanks but when you hit a big bump does anyone have a problem?
Posted: August 14th, 2009, 8:04 pm
by Mx3Kid16
cricketol2 wrote:this is what i got .. is this right idk please someone help
my friend just got these for his crx. TAKE OUT THE ADJUSTORS! and just put the springs right on the bottom plate.
SOOO LOWWWW
