In Dire Need of a Ignition Switch !!!
Posted: July 14th, 2009, 4:02 pm
by PatMX3
Hi guys, i need a new or used mx ignition switch. i got a 93 tilt/auto. V6 ill buy the switch itself or the column. I tried ebay & local junk yards, but none. Anyone in here know of someone who got it?.
Re: In Dire Need of a Ignition Switch !!!
Posted: July 14th, 2009, 4:45 pm
by umcamara
I've got an ignition switch, but I jammed a screwdriver into the tumbler, so not sure if locksmith can fix that.
Posted: July 14th, 2009, 7:30 pm
by hgallegos915
My second one is going on me..
I got one from another mx3 , I swapped out the inner gold key teeth(NEED ALOT OF PATIENCE) so I could use the same key.
Posted: July 14th, 2009, 7:33 pm
by umcamara
You may get better results in the "Want to Buy" forum.
Also, there are many people parting out cars in the "For Sale" forum.
Posted: July 14th, 2009, 8:30 pm
by PatMX3
Thanks guys! i'll try those forums. UMCAMERA* hey, let me know if u want to sell the switch ok?. id be interested!!.
Posted: July 15th, 2009, 4:44 pm
by nolig2278
what are the symptoms of failing switch and what needs to be replaced?
I can rarely start my car with the key, i usually just use the remote start
Posted: July 15th, 2009, 5:31 pm
by umcamara
Symptoms would be that you can't turn the key in the ignition, or the key gets stuck in the ignition. The tumblers inside the cylinder would have to be replaced or reset.
Make sure your floor mat isn't bunched up under the clutch pedal, this would keep the car from starting.
