klze swap coolant sensor
i am doing a KL swap and on my k8 there is a coolant sensor that is mounted to a bracket and goes undert eh fuel rails, my ze does not have this sensor do i need this sensor or no?
Re: klze swap coolant sensor
You don't but you will need the 94+ V6 ecu (if this is the sensor that's in the proximity of the oil cap), otherwise the fans will stay on high at all times.
'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
'93 Ford Probe GT - a few mods... 10.24 @ 139.5 mph [20 psi] - 545 whp, 490 wtq @ 21psi
1997 Ford Probe GTS (Hybrid) - RWD Conversion - Build Thread
