K8 issue maybe?
K8 issue maybe?
Alright so when im cruising at like 65-70, after a while my check engine light would come on and its strange to me because it doesn't stay on. Once I get where im going and cut it off it goes away. I feel like ever since I had midas do a oil change it has come up but then again I don't want to go to them and be like "wtf" until i get word from you guys that still have or had k8s. Now when I do city driving, no issues, no check engine light, nothing. Thanks in advance guys.
- Ryan
Re: K8 issue maybe?
Pull codes. Simple as that.
http://www.mx-3.com/phpBB3/viewtopic.php?f=24&t=65390" onclick="window.open(this.href);return false;
Re: K8 issue maybe?
even if it goes away and only comes up when im on the hwy?Ryan wrote:Pull codes. Simple as that.
- mitmaks
Re: K8 issue maybe?
it should have code(s) stored if it had CEL on
- Ryan
Re: K8 issue maybe?
If you had taken a second to read to the second paragraph...
Intermittent Failures
Intermittent failures may cause CHECK ENGINE light to flicker or illuminate and go out after the intermittent fault goes away. However, the corresponding trouble code will be retained in ECU memory. If related fault does not reoccur within a certain time frame, related trouble code will be erased from ECU memory. Intermittent failures may be caused by a sensor, connector or wiring related problems.
