Projetor light blows bulbs?
I installed my projetor lights about four or five months ago,went in fine good fitment and all so very happy with that.But the first time the passenger driving light went out ,just thought bad bulb so i got a good brand and replaced them on both sides to be safe.two or so month later it went out again? Now the first time was about two or so months and again two or so months and only on the passenger side the other side is fine?Wondering has anyone had this problem ,can it be two bad bulbs or can it be the relay since mine came with a relay?Can get very expensive replacing bulbs every two months thanks everyone!
- onlytrueromeo
Re: Projetor light blows bulbs?
Do you have HIDs? My projectors didnt come w/ relays, however the wiring is terrible and my highbeams don't always work - I have to jiggle wires. I rewired 1 side, and that made it perfect, have not had time to do the other side yet. I would try doing this.
- mitmaks
Youre not touching them with your hands do you?
Did you get the projectors with the relays?? I got those and have had them in for about 4 months now no problem. BUT a buddy of mine got the same ones and attatched the little red wire with an eyelit to the body (ground) and they started blowing. I have not used the little red wire for anything and they work fine.
I got just the standard H1 bulb,and no l made sure l didnt touch the actual glass part and for the little red wire with the eyelit the only one l see is the one with a 20 amp. fuse which l attached to the battery.
