94 GS CEL
Posted: May 23rd, 2009, 1:13 pm
by Mr_Shorty
Kinda of a stupid question. Do you need a ODB2 code reader for a 94?? I tried the paperclip and it didn't work. CEL comes on a few seconds after the car starts and doesn't shut off. Thanks
Tyler
Re: 94 GS CEL
Posted: May 23rd, 2009, 1:27 pm
by Mad Cow
94's are all OBDI so you use the paperclip trick. And you don't need to start it when you're checking codes.
Re: 94 GS CEL
Posted: May 23rd, 2009, 2:30 pm
by Mr_Shorty
I tried the paperclip and the light just comes on. No blinky...
Re: 94 GS CEL
Posted: May 23rd, 2009, 2:58 pm
by Whisper
TEN and GND yeh?
It shouldn't be on, if you don't start the car. Just turn the key to ON, it should click, and CEL should blink.
Re: 94 GS CEL
Posted: May 24th, 2009, 8:38 pm
by Mr_Shorty
I'm not actually starting the car when I'm checking for the codes. I only was telling ppl that so they'd know what was happening when the car runs. I did find out that the wire I used didn't make enough continuity to actually do the check. After using the proper wire (an actual paperclip) I got 4 blinks...'NE1' camshaft/crankshaft position sensor. Now to change it out.
Re: 94 GS CEL
Posted: May 24th, 2009, 11:51 pm
by Nd4SpdSe
Not all 94's are OBDI, but pretty much the large majority are.
Re: 94 GS CEL
Posted: May 25th, 2009, 5:16 am
by Whisper
For realz? I thought OBDII didn't come in until 95?
Re: 94 GS CEL
Posted: May 25th, 2009, 5:18 am
by _-Night-Shade-_
I believe it became mandatory in 96
Re: 94 GS CEL
Posted: May 25th, 2009, 7:51 am
by Mad Cow
_-Night-Shade-_ wrote:I believe it became mandatory in 96
Yea and mazda started using it around mid '95.
Re: 94 GS CEL
Posted: May 25th, 2009, 2:21 pm
by Nd4SpdSe
For the 94's you'll could actually come across it on a few Mx-3's, 95 they were pretty mainstream and 96's are 100% because it was mandated for that year.
Re: 94 GS CEL
Posted: May 25th, 2009, 9:32 pm
by Red Rocket
I've got an obd1 95, same f'in code
Re: 94 GS CEL
Posted: May 26th, 2009, 4:01 pm
by Nd4SpdSe
Which code?
Re: 94 GS CEL
Posted: May 26th, 2009, 5:30 pm
by Red Rocket
Code 4, we both have. His is prolly the crank sensor, mine is deffinately the cam sensor.
