help with seized ex mani nut. RESOLVED
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
not sure if anyone has seen my log or not. I'm having issues removing a nut on my exhaust manifold. It's the lower-far left nut. I've managed to round it off with the impact gun and I don't seem to have much room to work with, in order to cut it up one side. Any ideas? I drenched it in liquid wrench several times and torched it pretty good with a heatgun. Not luck yet.
This is what I am working with:
http://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=69074" onclick="window.open(this.href);return false;
I'm thinking the stud is going to be a lost cause and that I'll have to cut it off.
Ryan
Re: help with seized ex mani nut.
Post by Ryan »
wost case scenario zip it off and drill out the stud and use a larger one.
If you rounded it out, that sucks. hard to get at with any tool anyway. I'd cut it off and work with the stud.
Post by wytbishop »
You're not using the stock manifold are you? I would pull that bracket off and then I think you'd have enough room to get a dremel tool with a cutting wheel on the side of the nut. You don't have to cut all the way through the nut. If you can get a healthy notch int he side and then whack it with a cold chisel it should come off.
If you don't have a dremel tool...you should get one. Everyone should have a dremel. Everyone.
RS_OBD'oh_2
I do have a dremel. but I went out and got a right angle die grinder with a diamond cut off wheel. I guess I'll keep at it. Thank you guys.
RS_OBD'oh_2
well... it looks like I have today off. LOL, should have checked my calendar the other day. I'm going to try the dremel flex bit to see if I have more room to cut that f'n nut off. RAGE FTW! :twisted:
umcamara
Post by umcamara »
I don't know how safe it would be to go at it with a blow torch. But a blow torch and vice-grips can do wonders.
'98 BMW 328is M-Tech
Feedback Thread
cjthor
Post by cjthor »
after you cut the nut off you can go to your local tool supplier and get a stud remover. works wonders!!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
RS_OBD'oh_2
how much of the stud do I need to have showing to use the "stud remover"?
thanx for the help so far.
RS_OBD'oh_2
help with seized ex nut. resolved
that biatch is off! :2thumbsup:
Ryan
Re: help with seized ex mani nut. RESOLVED
Post by Ryan »
off and out? what'd you end up using?
RS_OBD'oh_2
I had a diamond cut off wheel.. that just didn't do it. So I took out the ol' die grinder and a steel bit.. took off half the nut in 2 mins. Then I hit it with an air hammer. Didn't take long after the air hammer.
Thanks to every one who helped out!
