Transmission for ZE
Transmission for ZE
hey guys whats the best transmission to put with the ze or is there even besides the k8
- Ryan
Re: Transmission for ZE
depends what you want. Research!
do you want acceleration, fuel economy, mix... longer or shorter gears... many many options.
well prolly a transmission good for racing at the tracks
im interested in this tooramsen25 wrote:hey guys whats the best transmission to put with the ze or is there even besides the k8
What kind of tracks?
You have 2 options:
4.39:1 - Mx-3/Probe
4.11:1 - Mx-6/626
You have 2 options:
4.39:1 - Mx-3/Probe
4.11:1 - Mx-6/626
k8/probe gt tranny would be good for most tracks
94 mx3 rs
92 mx3 gs curved neck klze SOLD
someone told me the k8 tranny is good for 1/4 mile but wouldnt be good for circuit i dont understand what they meant by the i figured because at low speed the tranny is reving really high
no, k8 trans is too short for drags, on a fast car you'll need 5th and 1st gear is pretty much useless.
K8 trans so far for me was great for autocross, and it could be used for circuit if you don't need to go faster than 240km/h
Forgive my ignorance but a few years back we knew a few things and things we knew was at the end of the 1/4 mile your should be about to hit your red line. That way your gearing is set to maximize your engines RPM's. So in that case wouldn't the K8 tranny be good?
Yes, that is right, but I've redlined in 4th and I've onl really ran 15's, but a few times, probably on slicker tracks, I've had to use 5th....
Ya 5th blows like 3rd in a 3 speed tranny. Meant for fuel economy I think not performance. So what do we do.
For what I've been told and actually seen, you actually top out in 3rd rather than 4th with the 4.11:1. I've heard mixed stories about people being quicker with the 4.39 and others with the 4.11, so it's hard to say, but I believe that the 4.38 would be too short.
- fieromx3
Nd4SpdSe wrote:Yes, that is right, but I've redlined in 4th and I've onl really ran 15's, but a few times, probably on slicker tracks, I've had to use 5th....
if your topping out 4th in the 1/4 mile that means you would be trapping like 105-110mph... ud need some miracle to do that on a stock block ZE...
and your car always trapped max about 93mph? thats about 150kmh and 4th will redline about 170kmh or just past
the stock mx-3 trans is better for 1/4 mile and circuit racing u want the tighter gears. the only way an mx6 trans will be beneficial is if u have a few hundred horse where the engine can take use of the longer gearing.
1st gear on a mx6 trans or mx3 trans will ALWAYS be pretty much useless on any ze
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
Im going to assume dragracing here.
Hard as I try I simply can't get my KLZE to produce torque.
Hence the 4.39 final drive.
basicly I use a G25M gearbox though fith has been removed
and I have a spacer and plate in place to stop blowing the
bearings out!
Use a sprung center clutch use your on a hiding to nowhere breaking stuff!
bearings out!
The difference is fairly minimal but when you are highway cruising you rev 400-500rpms less, which helps a bit for fuel economy.
As for speed - I don't think you would gain much with the K8 tranny. The MX3 is the lightest car you can commonly put a ZE into - having short gears won't help as much IMO. If the car weighed heaps more than I would say a tight K8 box with a 6th gear would work good.
1995 Eunos 30x KLZE
