The perfect ar for a klze?
Posted: April 14th, 2009, 10:23 pm
hmm getting into this turbo business a bit deeper... now that its super easy to make ebay turbos work(ill post pics later about how its done)
ok so the turbo I had had a cold side ar .60 and hot side had an ar .53 that turbo ran greatr, boosted around 2700 all the way to 6000.
Ok so i came across some money and since that turbo had a bit of play i decided to buy another ebay turbo.. well
the housing in my pipes is for the ar.53 so I had to use my old hot side and the cold side now i have an ar.50 It sure makes the blow off valve sould likie crazy and builds nice boost all the way to 6k rpms. This one dies out a bit at around 6k but can still go.
Anywho.. what ars are you running for your boosted kl engines??
