diagnostic codes
Posted: April 2nd, 2009, 7:47 pm
by blaudust7
I Have code 5, which I have no idea what it is, and I have code 15. What is the deal?
posting.php?mode=post&f=15#
Re: diagnostic codes
Posted: April 2nd, 2009, 9:12 pm
by projectzemx3
5 - knock sensor
15 - oxygen sensor
http://forums.probetalk.com/showthread. ... 1701015446" onclick="window.open(this.href);return false;
Posted: April 2nd, 2009, 9:16 pm
by RS_OBD'oh_2
ouch.
don't take this the wrong way.. do you know where to look up the codes in this site?
Posted: April 2nd, 2009, 9:23 pm
by projectzemx3
its only ouch if the knock sensor is doing its job. if the knock sensor has just failed then it just means a new knock sensor and thats that. but either way its a sucky job to do.
Posted: April 8th, 2009, 9:56 pm
by blaudust7
Could you explain the location of the knock sensor and where to find the codes on this site? It was not code 15, but 16, which I know is the EGR. My bad. I would greatly appreciate it.
Posted: April 8th, 2009, 10:19 pm
by Daninski
Look straight down from the top of your engine into the deepest depths right in the middle of your intake. What I was wondering is if your running high test gas who cares about the knock sensor. Anyway heres some codes.
http://forums.mazdaworld.org/index.php?showtopic=19709" onclick="window.open(this.href);return false;
Posted: April 8th, 2009, 10:28 pm
by projectzemx3
Daninski wrote:What I was wondering is if your running high test gas who cares about the knock sensor.
im confused...
Posted: April 8th, 2009, 10:38 pm
by Mad Cow
Daninski wrote:Look straight down from the top of your engine into the deepest depths right in the middle of your intake. What I was wondering is if your running high test gas who cares about the knock sensor. Anyway heres some codes.
Doesn't matter how much octane you're running, a knock sensor code will make the ECU retard the timing as a failsafe, so it'll run badly (I would know).
