OK so my problem all happened a month ago but i am finally trying to fix it here is whats wrong so it stopped working on a cold night about a month ago i went outside to get in it to go get some ciggerets well i hoped in and turned the key and it would just crank but not turn completely over... so i bought a new fuel pump thinking that might be it. Well I changed that and still same thing so i got in touch with my uncle who was a mecheniac this time he brought over his little snap on comp plugged it up and it said it was no spark and ignition so got new dist and got a spark now butstill not doing anything help me ?
Oh yeah and I just replaced
Disty.
spark plugs & wires
fuel pump
fuel pump relay
was not sure were to post this at
does not wanna turn over
Re: does not wanna turn over
Ok i feel like i repeat myself alot and this is probably a stupid question but i must ask. did you change the rotor/cap on the disty and are you getting weak spark?
Try taking a look at the CPS this will prevent the car from starting also
It was a brand new disty i found out the prob. the rotor cap was not on right they assembled it wrong the rotor fits on one way they forced the part on so i had to retuen it and get another one i was not to happy about it. but that for the advice anyway
