how to disconnect/bypass alarm and immobiliser on '93 mx3 v6
hi,
i lost my keys a few weeks ago and have now got to the stage of having searched hundreds of times for them and now just need to be able to start the car. is there any way of bypassing/disconnecting the alarm and immobilizer, if it helps the car is a '93 mx3 1.8i v6 24v.
if anyone can help please do i have searched web page after web page and found nothing that tells you how to do it they just say it can be done.
'92 MX3 1.8 DOHC 24 valve V6
- Custommx3
- Site Administrator
Re: how to disconnect/bypass alarm and immobiliser on '93 mx3 v6
Do NOT post this in other sections.
I would suggest conacting an installer who did the job, or the manufacturer of the alarm system.
it is all the standard installation and its just a case of being able to start the car and make sure she still runs and if shes fine i will put her back together and contact someone to find out about replacement keys and such
The '93 didn't have any sort of alarm or immobilizer, so we can't help you there.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
- fowljesse
I'm interested in the answer to this, also. I have an Alpine alarm, and it seems that the starter cut-off is permenantly open. I guess I'll have to find out which wire it is, and just bypass it. If I figure it out, I'll post what I did.
- cjthor
Jesse don't post how to bypass alarms...If you do so and some dork hops on here he can get some good info how to steal our precious cars!!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- fowljesse
Right-O.
I was just going to bypass the igntion interuptor switch. basically, I'm going to take it out of the original ignition wire from the switch to the starter.
i cant find my immobiliser anywhere!
its a finish line one - 94 v6 1.8
lost the remote on the weekend and i need to be able to drive the car desperatley
apparently i put my key in and press the button on the illusive immobiliser and hey presto it goes into a valet mode..... allowing me to get the car to an electronics specialist
ive checked under the dash... on both sides under the bonnet
has anyone got any ideas?
prehaps you can let me know common places where it is installed
this is really doing my nut in!!
cheers
s
cheers
s
Maybe it's behind the centre console where the ecu is.monkeynutcharlie wrote:i cant find my immobiliser anywhere!
cheers
s
yeh its more than likely down by the ecu because thats where mine is i am not going to go into ways of bypassing but i managed to do it in mine just using a bit of common sense so it cant be that hard
found it in the end to the right of the glove box
thanks!
s
thanks!
s
