NW oregon mx-3 projects
For MX-3 owners on the west coast and surrounding areas
Now that it's getting warmer and spring is finally deciding to show it's face I thought it would be cool if we could get a list together of things we want to work on and do either as a group or separately... just so we know what's going on with each other :D
For everybody:
Lexan for the hatches/ hatch installs
B-Pillar bars - I know we talked about this a while back
My list:
• Coolant system flush, adding water wetter
• Install SS brake line, master and slave clutch cylinders, replace brake pads,
• Brake system flush and replace with racing blue fluid
• Replace ball joints, get alignment
• Reprime race car (or flat black)
• PASS EMISSIONS :roll:
• Install new set of headers/ possible new muffler/ possible high flow cat if I can't pass emissions
• Make a true CAI by routing piping into front bumper
• When I get a new suspension system, installing that
• Install whiteline swaybar and wytbushings/ endlinks
• When LSD is ready, adding and rebuilding spare tranny
• Get DD running again... sigh :crying:
cjthor
Re: NW oregon mx-3 projects
Post by cjthor »
For me.....
*Finish pulling dash out
*Gut doors and lexan the side windows
*Finish roll cage
*Install custom intake/new TB
*Finish car trailer to take the MX to the track!!
I gave up on passing emissions a loooong time ago. I would love to find another red MX3 and keep it just for DEQ and plate my turbo car!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
mitmaks
Post by mitmaks »
Im in WA, so I'm pretty close
1. Need to do brake system flush (with speed bleeders installed it's a one man deal)
2. Clean up interior, haven't cleaned it since fall
3. Still trying to get SRD ebrake handle
4. Get new set of tires
cjthor
Post by cjthor »
Wellll....I ripped the dash out...Literally. Its not going back in thats for sure!
Jarid Perry
fowljesse
Post by fowljesse »
So, you used my "technique" :lol:
I'll write about my plans when I'm less frustrated with them. I finally found out that I need to pull the fuse for the alarm (which I don't know where it is), then disconnect the battery, to reset the cut-offs.. There are 3 fuses inline, and an extra fuse in the underdash box, so I'll pull them all, and see if it works.
mitmaks wrote:3. Still trying to get SRD ebrake handle
So am I! :shock: :?
Straighten front bumper a little
Install spyder headlites
HEI mod with coil
Alt being built to 120 amps
Complete body job and paint myself
Improve stereo
Replace Xmas tree air freshener
So am I! :shock: :?
lol I finally just got one... although it's not as spectacular as I thought it would be (not sure what my expectations were)
fowljesse
Post by fowljesse »
Beside putting in the hatch, I want to:
Get the thing running,
Install the wideband O2, and fine tune it,
Install Wytbushings,
Paint the car,
Finish the sound deadening,
Drive real fast.
Which reminds me; I need a Valentine Cop detector!
mitmaks
Post by mitmaks »
Now I need to figure out how come it stumbles on acceleration ~2500-3500rpm, almost like there's water/air in the fuel line or something
mitmaks wrote:Now I need to figure out how come it stumbles on acceleration ~2500-3500rpm, almost like there's water/air in the fuel line or something
I just had this issue and it would hesitate between 3-4krpm - it ended up being my 7 nipple disti that was bad (or at least the pickups inside or something)... put in another one and it runs like a champ now!
stereoking15
Post by stereoking15 »
not sure we will have a work day if i keep diagnosing and fixing all ur guy's issues. except for marks non running mx3 :roll: stuipid car, maybe try ecu now :shrug:
Return to “West Coast MX-3 Owners”
