Brake rotor size / compatibility
nightfire
Post by nightfire »
Hey guys,
I searched and couldn't find a definitive answer... probably because my search terms were too generic.. but,
Are the rotors from all years, and all models the same size? I'm about to buy fronts and rears from a guy on ebay who labeled them for a 94-95 4cyl "with ABS." I didn't know there even was such a beast; I thought ABS was limited to the GS.
http://cgi.ebay.com/ebaymotors/94-95-MA ... ccessories" onclick="window.open(this.href);return false;
Are they likely to fit my GS, or were there multiple rotors for our cars?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Re: Brake rotor size / compatibility
interesting question... I was under the impression that the brake rotors are the same for all years of the mx-3... however it is new information to me that ABS came on 4 cylinders (over in europe of course) and apparently the 4cylinder also had 4 wheel disc brakes? although this could just be a case of the ebay seller listing it wrong...
I would point you to the uk mx-3 forums but they are not working right now...
bump for those who can advise.
Hoodzy
Post by Hoodzy »
4wheel disc brakes are N/A on the RS
1995 Creek Mica Blue GS
so this topic got me thinking so I started browsing on ebay.co.uk and I found an mx-3 with the 1.6 engine that has rear disc brakes... I'm wondering if ANY mx-3 that has ABS has 4 wheel disc brakes? does ABS work with drums?
http://cgi.ebay.co.uk/1993-MAZDA-MX-3-1 ... 240%3A1318" onclick="window.open(this.href);return false;
marcdh
Post by marcdh »
UK 4 cylinders are common enough with discs all round, from what I've noticed! That one you've linked has discs on the rears too.
View Worklog
Ask any parts place if the PN's are different for different years of models. I'll go look in Rockauto.com and see what they list.
taylor_matt
Post by taylor_matt »
Yeah i was also wondering if the 94+ RS and GS models were the same, pertaining to break lines and such.
Sorry nightfire, don;t mean to steal your thread, i just thought this was relevant. :)
nightfire
Post by nightfire »
taylor_matt wrote:Yeah i was also wondering if the 94+ RS and GS models were the same, pertaining to break lines and such.
lol by all means. :) More info the better.
- Gord
