2 OEM Tail Lights. They both work fine. They include wiring harness and bulbs.
The drivers side one has a slight crack as seen in the pictures. Also have the passenger tail light weather guard.
How does $40 shipped sound?
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/S7300422-1.jpg)
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/S7300421-1.jpg)
1 OEM Front Left Driver Side Marker. $5 Shipped in USA.
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11215-1.jpg)
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11216-1.jpg)
KL07 ECU from 1993 Probe GT 5 speed KLDE. It worked fine when I pulled it.
$50 shipped.
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11209-1.jpg)
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11208-1.jpg)
OEM Air Flow Meter / Mass Air Sensor with elbow for a KLDE.
$45 shipped.
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11210-1.jpg)
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11211-1.jpg)
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11212-1.jpg)
KLDE Throttle Body. It is complete with the IAC and TPS. It is off a KLDE. Worked fine when pulled.
$35 shipped.
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11217-1.jpg)
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11218-1.jpg)
KLDE Distributor. It worked fine when I pulled it.
$55 shipped.
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11219-1.jpg)
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11220-1.jpg)
I have a used set of Durabrand Plug Wires from a KLDE. Only used for less than 6 months. They worked fine when I pulled them. $20 shipped.
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11229-1.jpg)
OEM V6 badge. $7 shipped!
![Image](http://i292.photobucket.com/albums/mm27/pauleatstoomuch/SDC11241-1.jpg)
Brand New Timing belt for DOHC B6. It came with a new set of pulleys. $25 shipped.
Pics upon request.
OEM shift knob. $10 shipped.
Pics upon request.
Cigarette Lighter assembly from 92-93. $5 shipped.
Pics upon request.
Brand New KLDE Valve Stem Seals. Never opened. $10 shipped.
Pics upon request.
I will take paypal please. I am out of a job, and cleaning out extra stuff. I can also take more pictures if you like. Thanks for looking!
