Very strange noise from rear suspension
nightfire
Post by nightfire »
I've got this funny noise coming from the rear suspension (I assume). I've never heard anything quite like it on a car before.
It sounds almost like beer empty bottles in a 2-4 in the trunk. Kinda like a jingling, metal on metal, or metal on glass. Maybe like a really heavy, thick washer loosely rattling on a thick bolt.
It happens under road vibration (small cracks in the road).
It started after I changed my wheel bearings. I assumed maybe I left a tool somewhere and it was jingling, but I looked and looked, and nothing. Wheels are both on tightly with no play. Everything on the suspension looks fine. Spare tire well is empty.
Top plates and main strut bolt are secured.
I'm baffled. Any ideas?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
solo_ryder
Re: Very strange noise from rear suspension
Post by solo_ryder »
Wierd...
Have you checked your hatch? Maybe the striker needs to be moved down abit.. Throw a peice of tape on the latch loop too.
nightfire
Post by nightfire »
solo_ryder wrote:Wierd...
Yep, checked it. It's tight and well greased.
The noise seems to be coming from the left side of the car and seems to be louder with the window open, so might be originating from outside. :/
- Gord
I have anti rattle compound on my brake pads.
