The TPS broke and the guy couldn't figure it out, he said it kept loosing power and he would push down the pedal and nothing would happen. So he parked it because it wouldn't start one day. Two years later, I got it, unplugged the TPS and it worked. So I just kinda slapped a new used tps in there. Seemed to work good without adjustment.
So, I tried to drive it down to Costco on the 2 yr old gas, and it made it ok, was guttless, and so I blamed the gas. Got down, and it started dieing. It died driving away, and going down the hill out of costco. I finally made it back and it seemed powerless. So I bought feeler gauges, adjusted the TPS to factory specs, adjusted idle, and thought it was good to go.
Well today I took it for a test drive, and it was still just powerless, so I tried to adjust the timing, and the distributor was turned completely advanced, and that seemed the only way to keep it running. But, I set it to the factory 10 degrees advanced, let it idle for like 5 mins, and it died. Tried to restart, no dice. So Finally after waiting for 5 mins, it started, very poorly, barely running! Advanced the timing, and then noticed every time I step on the brake the RPMs drop way low, and the car almost dies. So I went through and checked for vac leaks, none.
So here I am open for ideas. I am thinking possibly:
Dirty injectors
Bad Distributor
Bad Coolant Sensor (Seems to only do it when it is warm... maybe)
Vac Leak Still
bad brake booster
Something Electrical!!!
So if anyone has any thoughts, the ECU still blinks code 12 for the TPS... So I have tried to reset the ECU, but still won't! I am so flustered!
