gasket kit off ebay
ramsen25
gasket kit off ebay
Post by ramsen25 »
hey everyone has anyone ordered a gasket kit off ebay and if so r they good enough or they garbage
hgallegos915
Re: gasket kit off ebay
Post by hgallegos915 »
They are the same stuff that they sell on autozone.
I bought the oil gaslet for the valve covers for like 15 dllrs, it was good.
-hec
ramsen25
Post by ramsen25 »
k kool thanks
fieromx3
Post by fieromx3 »
the valve cover gaskets seem crap... 3 guys bought the kit and have not a problem with them. i would only change headgaskets and valve cover gaskets to mazda though
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
RX8SE3P
Post by RX8SE3P »
fieromx3 wrote:the valve cover gaskets seem crap... 3 guys bought the kit and have not a problem with them.
Is it just me or does that make no sense? They seem crap but three guys have them and had no problems???
I would use Mazda genuine for the head gasket since it's hard to access without taking the engine out but valve cover gaskets, timing belts etc I would simply use aftermarket stuff like on ebay.
1995 Eunos 30x KLZE
ramsen25
Post by ramsen25 »
should i even bother changing the head gasket since there r low k on the motor or thats wut they say, or maybe just change just in case
Ryan
Post by Ryan »
Whats the apropriate way to clean an gasket surface? I've been scraping my minor ones with razors, but I don't wanna mess up on the headgasket...
thebonestockkid
Post by thebonestockkid »
Holy... if you're going to go through the trouble of a head gasket, just do yourself a favor and go to Mazda for OEM s--- that you can trust
Image'97 Grenada black pearl Acura EL, JDM B18C 98spec ITR Swap. Power in Control full coilovers going in next spring. Not to mention a most unusual whining noise... coming soon.
'92 Intense blue pearl Jeep YJ, OME lift, mudders, fun.
R.I.P.
'93 Clear white GS-DE ~14.648@92.98mph, 2.234 60ft. PARTING OUT PM ME.
RX8SE3P
Post by RX8SE3P »
ramsen25 wrote:should i even bother changing the head gasket since there r low k on the motor or thats wut they say, or maybe just change just in case
If you're swapping a low km motor, don't bother changing the head gasket IMO.
1995 Eunos 30x KLZE
ramsen25
Post by ramsen25 »
k thanks
Mnemonic
Post by Mnemonic »
i mean seriously it cost about 120 dollars to get every gasket/seal from the dealership...
Why buy the cheaper stuff and save like what 50-60 bucks?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
tmac4t4
Post by tmac4t4 »
Ryan wrote:Whats the apropriate way to clean an gasket surface? I've been scraping my minor ones with razors, but I don't wanna mess up on the headgasket...
if you have acess to an aircompresser, or a drill for that matter, just use a wire wheel..should polish it up nicely
Ya I bought mine from the Dealership with 20% off. No probs. Install them with the proper silicone. Its used on every corner. I actually placed a very small bead on my entire head surface. No leaks for me. :) Once you apply the silicone your suppose to wait 15 minutes before torquing down the covers. Its in the manual anyway. Rockauto is pretty good to.
ramsen25
Post by ramsen25 »
i gotta add silicone with the new gasket, wut kind of silicone
fieromx3
Post by fieromx3 »
ya all other gaskets SEEM good but even the headgaskets so far have been holding up but the valve cover ones have always leaked... just misunderstood me
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
