Ok so i'm in the middle of this BP swap an besides the wiring part i'm also having some issues with the fuel hoses and stuff.
Now i apologize, your probably going to have to guess at what i';m talking about since i'm not quite sure. I think they are the injectors which i am trying to connect right now. They have 4 small tubes coming out of it (2 from each injector?) and each have a plug in. As far as i know, some plug into the intake and some into other places.
Maybe if someone has a diagram of the fuel lines coming from tank and into everything else for the BP that would help.
Oh and i have been searching for over an hour so i'm not just being lazy and getting others to do the work.
Thanks in advance.
Need some help hooking up fuel lines for BP
- taylor_matt
Re: Need some help hooking up fuel lines for BP
A few things to note is there is a Protege fuel rail and not the Escort GT and my
fuel pressure regulator is just a hose where the stock one should be.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
The fuel injectors don;t have hoses going to them, let alone two little hoses. I think you may be referring to the two solenoids (VICS AND PRC) near the passenger side of the intake manifold? On has a white connector and the other an brown/orange/pinkish connector. Yes/no?
Hose diagram
viewtopic.php?f=48&t=66826&hilit=vics+solenoid" onclick="window.open(this.href);return false;
Hose diagram
- taylor_matt
yes! thats exactly what it is. i'm not sure if i can figure that diagram out tho.
