Hi, now the winter is coming I have just tried my heater and it doesnt switch on. I have checked all the fuses and they are fine? Coolent level is fine. It must be electrical becase the blower doesnt run. Any idea's?
Thanks
no heat blowing- climate control
- Ryan
Re: no heat blowing- climate control
If you turn your car on without starting it, does it make any noise? We don't have a cabin filter so its possible someone built a home in it
How do i find i diagram to get at the motor? also where is it?
Well if the fan's now blowing, than ya you've got an issue with the blower, either in the controls or the fan/fuse. The controls don't nomally go completely, usually you'll lose one of the lower 1-3 but max (where there is no resistance) will still work
You should still feel some heat radiating from the vents, especially as you drive, but if you don't, your thermostat may be shot, and you can tell that because it'll either take a LONG time or never get up to running temp.
- Newfie_dan
check under the passengers side up against the firewall see if any wires are disconnected or burnt off.
