my heaters dont seam to blow out hot air just kinda warm after its been running almost a hour, any sujestions.
and my rear demister dont work ant advice on how to fix that
heaters and rear window demister
Re: heaters and rear window demister
maybe could be your thermostat stuck open or even heater core
- fowljesse
Check the tabs that connect your defroster to the wires on each side. If they're not connected, you can get special glue for it at the parts store.
