[FS] My random parts sale - More Millenia S injectors
My garage is getting filled up so I want to see if I could make some extra money on stuff I don't need. Every price is OBO. I'll be willing to ship items out, but local pickup is preferred. All prices exclude shipping.
Most parts are from an unknown mileage, likely '92 GS.
K801 ECU, perfect working condition, but the back around the EPROM chip is a bit scratched up due to soldering: $35 (Note, does not come with brackets, I just sill haven't taken them off)
24 HLA's: $15
Some pulleys and bearings, seem good: $10 (Accessory tensioner sold)
Timing belt crank and cam pulleys: $30 for crank pulley or 2 cam pulleys
Power steering pump: $30
3 sensor coolant neck: $5
K8 cams: $40
'95+ distributor (6-pin connector is slightly broken, but everything plugs in fine, I thought all distys were the same when I bought it): $60
Set of 6 Millenia S red top injectors, these are a bit aesthetically worse than the last set, but they came from a car with 220xxx km/s on it: $110
Gauge cluster backplate painted white: $10
JE50 TPS: $15
Passenger side power window switch (can also thrown in the harness and motor for a bit extra) $10
KL01 TPS: $20
'94+ hazard switch: $5
3 '94+ dash vents (The ones that attach to the cluster surround panel): $10
4 tweeters (2 off a celica and 2 made by MA Audio): $5 each
24 HLA's: $15
K8 cams: $40
JE50 TPS: $15
KL01 TPS: $20
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
Re: [FS] Various K8 parts
is the tensioner seized? i'm new to the k-series v6 engines...this will fit on a 2.5v6? i'll be changing my accessory belts in the near future.
.::Mazda::speeD::.
working on the 2nd part
If you're talking about the manual tensioner then it rolls perfectly and the bolt isn't seized. I'm not sure if it's the same as the KL series, but I would bet that it is.
Bump, some stuff sold.
Bump, come on I need the money.
Bumpity
Do you have the stock k8 flywheel?
-hec
Sorry, no I don't.
Bump...
How much for the power steering tensioner
do you have the fuel pump relay and or the nuts and bolts and rubber peices for the crossmember/ bottom motor mounts
Re: [FS] My random parts sale [Updated]
Some new parts for sale
did that PS pump leak at all? im interested. how does the bearing look in it? still orange or kinda brown from being old?
NEED PARTS INSTALLED? PM ME!
Got an oil pan
[*url=http:cardomain.com/ride/2632839]My Cardomain Page[/url*]
