Cluster gauges, bad bulb?
When i turn my head lights on, the speedometer, tachometer, fuel, and heat gauges dont light up. my e-brake, and all those other lights work. so my question is, are the four gauges i mentioned earlier all lit up by one bulb that could have burned out, or do you think its a deeper problem?
tom
- Ryan
Re: Cluster gauges, bad bulb?
Its multiple bulbs, and check fuses.
