I forgot how to do OBD testing since I havent done it in a long time.
I already ran TEN and GRN on the diagnostic box.
The CEL is flashing.
However, I looked on the FAQs and they dont mention how to read or add up the numbers. Like I understand that every long flash means 10. Every short flash means 01 and whenever it dont flash, it means 0.
But I seen the flashes, wrote them down, and they dont add up to any codes.
Someone help?
Here are the codes I get.
1 long flash
(blank light, pause)
<flash> <flash> (2 quick flashes)
<flash> <flash> <flash> (3 quick flashes)
1 long flash
<flash> <flash> <flash> <flash> <flash> <flash> (6 quick flashes)
(blank light pause)
(blank light pause)
1 long flash
(blank light pause)
(blank light pause)
[Keeps repeating]
Quick OBD testing question
Juans_93_MX3
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Juans_93_MX3
Re: Quick OBD testing question
Thanks. I see how it works nowshameem wrote:You have codes 2,3 & 16
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
how did u add it up to get those CEL code numbers?
