KL-ZE starter
Posted: October 12th, 2008, 1:15 pm
by MAZDA SPEED MX-3
i read that you can use the 1.8 fly wheel in the 2.5 tranny when doing the swap.is this true. and if so what starter would i need, a 2.5 MT starter?
Re: KL-ZE starter
Posted: October 12th, 2008, 1:34 pm
by marcdh
Yes you can saving you 5lbs or whatever on the flywheel.
IIRC:
k8 - 16lbs
KL - 21lbs
Fidanza - 9.3/9/5lbs
Aasco - 9.5 lbs
Either starter works to my knowledge, being as the entire tranmissions amongst the K series v6s are interchangeable.
Re: KL-ZE starter
Posted: October 13th, 2008, 8:29 pm
by Mooneggs
marcdh wrote:Fidanza - 9.3/9/5lbs Aasco - 9.5 lbs
Fidanza and Aasco are 9 pounds...
Re: KL-ZE starter
Posted: October 13th, 2008, 11:33 pm
by Daninski
Stock, mx-3 starter
Re: KL-ZE starter
Posted: November 5th, 2008, 6:36 am
by RX8SE3P
My swap is almost done. I'm using the KLZE starter, but that's because it came with the tranny I got for it.
If you use stock gearbox I guess you should use stock starter.
Re: KL-ZE starter
Posted: November 5th, 2008, 8:59 am
by marcdh
Mooneggs wrote:marcdh wrote:Fidanza - 9.3/9/5lbs Aasco - 9.5 lbs
Have to say my fidanza was more like 9.3lbs for what it's worth...(not much
Re: KL-ZE starter
Posted: November 7th, 2008, 9:00 pm
by V8KOMX3
you can use the starter from the 1.8 or a 2.5 motor either works
Re: KL-ZE starter
Posted: November 8th, 2008, 4:35 am
by DimaK
since when k8 flywheel weights 16 pounds, its 11
Re: KL-ZE starter
Posted: November 8th, 2008, 12:37 pm
by thebonestockkid
DimaK wrote:since when k8 flywheel weights 16 pounds, its 11
News to me
Re: KL-ZE starter
Posted: November 8th, 2008, 5:38 pm
by solo_ryder
lol its not 11 pounds.
Re: KL-ZE build FLYwheel
Posted: November 8th, 2008, 10:49 pm
by MAZDA SPEED MX-3
well turns out i need a new starter any way so i'll go with stock, problem is i need a new flywheel do to the fact that mines all nice and blue and cracked. I cant get a stock one from advanced and wasn't able to find one on rock auto or google shopping. I would like to stay away from a pricy fidanza. And I dont think one from a junk yard would be a good idea. ill keep searching, any suggestions would be appreciated. thanks in advance.
Re: KL-ZE starter
Posted: November 8th, 2008, 11:10 pm
by solo_ryder
Junkyard is fine. U just need to go get it resurfaced.
Re: KL-ZE starter
Posted: November 9th, 2008, 12:30 am
by Daninski
Answer the question and keep your petty arguements to your selve. I'm glad I never get into any disagrreements here.
Any 1.8 or 2.5 Flywheel will work fine.
Re: KL-ZE starter
Posted: November 9th, 2008, 2:57 am
by MAZDA SPEED MX-3
sweet deal. it's cheap too. thanks solo. and thanks daninski
