KL-ZE starter
MAZDA SPEED MX-3
KL-ZE starter
Post by MAZDA SPEED MX-3 »
i read that you can use the 1.8 fly wheel in the 2.5 tranny when doing the swap.is this true. and if so what starter would i need, a 2.5 MT starter?
marcdh
Re: KL-ZE starter
Post by marcdh »
Yes you can saving you 5lbs or whatever on the flywheel.
IIRC:
k8 - 16lbs
KL - 21lbs
Fidanza - 9.3/9/5lbs
Aasco - 9.5 lbs
Either starter works to my knowledge, being as the entire tranmissions amongst the K series v6s are interchangeable.
View Worklog
Re: KL-ZE starter
marcdh wrote:Fidanza - 9.3/9/5lbs Aasco - 9.5 lbs
Fidanza and Aasco are 9 pounds...
Re: KL-ZE starter
Stock, mx-3 starter
RX8SE3P
Re: KL-ZE starter
Post by RX8SE3P »
My swap is almost done. I'm using the KLZE starter, but that's because it came with the tranny I got for it.
If you use stock gearbox I guess you should use stock starter.
1995 Eunos 30x KLZE
marcdh
Re: KL-ZE starter
Post by marcdh »
Have to say my fidanza was more like 9.3lbs for what it's worth...(not much :lol: )
View Worklog
V8KOMX3
Re: KL-ZE starter
Post by V8KOMX3 »
you can use the starter from the 1.8 or a 2.5 motor either works
Teal 1993 MX3GSZE
DimaK
Re: KL-ZE starter
Post by DimaK »
since when k8 flywheel weights 16 pounds, its 11
thebonestockkid
Re: KL-ZE starter
Post by thebonestockkid »
DimaK wrote:since when k8 flywheel weights 16 pounds, its 11
News to me :lol:
Image'97 Grenada black pearl Acura EL, JDM B18C 98spec ITR Swap. Power in Control full coilovers going in next spring. Not to mention a most unusual whining noise... coming soon.
'92 Intense blue pearl Jeep YJ, OME lift, mudders, fun.
R.I.P.
'93 Clear white GS-DE ~14.648@92.98mph, 2.234 60ft. PARTING OUT PM ME.
solo_ryder
Re: KL-ZE starter
Post by solo_ryder »
lol its not 11 pounds.
MAZDA SPEED MX-3
Re: KL-ZE build FLYwheel
well turns out i need a new starter any way so i'll go with stock, problem is i need a new flywheel do to the fact that mines all nice and blue and cracked. I cant get a stock one from advanced and wasn't able to find one on rock auto or google shopping. I would like to stay away from a pricy fidanza. And I dont think one from a junk yard would be a good idea. ill keep searching, any suggestions would be appreciated. thanks in advance.
solo_ryder
Re: KL-ZE starter
Junkyard is fine. U just need to go get it resurfaced.
Re: KL-ZE starter
Answer the question and keep your petty arguements to your selve. I'm glad I never get into any disagrreements here. :) Any 1.8 or 2.5 Flywheel will work fine.
MAZDA SPEED MX-3
Re: KL-ZE starter
sweet deal. it's cheap too. thanks solo. and thanks daninski :2thumbsup:
