No Spark and No Start
Posted: September 6th, 2008, 2:53 pm
by Gunner202
My 94 GS wasn't starting due to lack of spark. Checked everything I could think of and decided it sounded like a distributer problem so I decided to do a HEI mod with ext coil. After performing the mod I'm still not getting any spark and the car still won't start. Any ideas would be great....
Re: No Spark and No Start
Posted: September 6th, 2008, 9:12 pm
by Savin
Check grounds
Check for power going into distributor
Check disty wires
Check your HEI/Ext. Coil mod wires.
That's all I can think of.
Posted: September 6th, 2008, 11:30 pm
by mx3boyze
Was the motor swapped or anything? Was the timing redone anytime recent? Might try a different ecu, maybe the ecu is shot.
Posted: September 12th, 2008, 3:55 am
by Gunner202
Thanks for the replys and to anwser your questions I don't believe the motor has been swapped. I believe it's the original 1.8. Any ideas how to get my hands on a new ecu?
Posted: September 19th, 2008, 12:25 am
by purewhitemp5
pull the coil wire out of the dist., insert a screwdriver , hold screwdriver next to a piece of grounded metal , have someone crank the engine , are you getting a spark ??
