No Spark and No Start
Gunner202
Post by Gunner202 »
My 94 GS wasn't starting due to lack of spark. Checked everything I could think of and decided it sounded like a distributer problem so I decided to do a HEI mod with ext coil. After performing the mod I'm still not getting any spark and the car still won't start. Any ideas would be great....
Savin
Re: No Spark and No Start
Post by Savin »
Check grounds
Check for power going into distributor
Check disty wires
Check your HEI/Ext. Coil mod wires.
That's all I can think of.
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
mx3boyze
Post by mx3boyze »
Was the motor swapped or anything? Was the timing redone anytime recent? Might try a different ecu, maybe the ecu is shot.
Gunner202
Post by Gunner202 »
Thanks for the replys and to anwser your questions I don't believe the motor has been swapped. I believe it's the original 1.8. Any ideas how to get my hands on a new ecu?
purewhitemp5
Post by purewhitemp5 »
pull the coil wire out of the dist., insert a screwdriver , hold screwdriver next to a piece of grounded metal , have someone crank the engine , are you getting a spark ??
