Turbo
MazdaRider
Turbo
Post by MazdaRider »
hey all u guys runnin a turbo
im thinkin of up grading 2 one
but heres a quick question if i do
do i also need 2 up grade my ga 2 premium
instead of regular unleaded
lazzer408
Re: Turbo
Post by lazzer408 »
Depends on your compression ratio, ignition timing, effectiveness of the intercooler, a/f ratio, and everything else that can attribute to detonation. Octain being one of them. Assuming your engine is stock otherwise, yes you'll need to run premium. You might get away with midgrade if your boost level is low and you have good boost timing retard.
onlytrueromeo
Re: Turbo
Post by onlytrueromeo »
I would do some more research before you put a turbo in - it seems like you've got a bit to learn :) Check out the forced induction part of the forums.
MazdaRider
Re: Turbo
current mod's r a 3'' CAI
Exhaust
Whole NGK ignition
so far as engine :|
RS_OBD'oh_2
Re: Turbo
Post by RS_OBD'oh_2 »
So, that is what we called stock.
Read up and see what options there are for you. First things we need to do is make sure that you do not have and auto tranny, or sohc. Second we need you to read maximum boost. Then decide your power goals and save lots of money. What fuel to use is really the last thing you need to worry about. Anyone can fill a tank.
Re: Turbo
Unless he's worried about gas prices, but if your running boost, it's highly recommended if not needed to run a higher octane fuel since your increasing the (dynamic) compression of the motor. Ona vehicle that is stock turbo/supercharged, you can get away with lower octane since the car's computer will know how to deal with it and adjust everything to compensate, however adding a turbo and running on a stock system, if you don't, you'll run the risk of blowing the motor
RS_OBD'oh_2
Re: Turbo
Someone else brought this up a while ago. IMHO one can not want to drop a few thousand on a turbo set up and then cry about the price of premium. With a good tune one could get awesome mileage.
Re: Turbo
RS_OBD'oh_2 wrote:one can not want to drop a few thousand on a turbo set up and then cry about the price of premium.
If you want to play, you gotta pay.
It's ironic, these days of people going fuel efficient, our family, we have 4 cars, ('02 AWD Escape, '99 3.2TL, ZE Mx-3 and Supercharged Xterra) all are v6's, 3 take premium (Mx-3, TL & Xterra). Guess we just like ours cars :)
MazdaRider
Re: Turbo
na is 5 speed DOHC
neli_nael
Re: Turbo
Post by neli_nael »
lazzer408 wrote:good boost timing retard.
where do you adopt one of those?
94 mx3 rs
92 mx3 gs curved neck klze SOLD
lazzer408
Re: Turbo
Post by lazzer408 »
I run the AEM EMS (stand alone) in the Miata and the AEM FIC (piggyback) in the MX-3. Don't even bother with the MSD boxes. For what they charge for a timing controller, you can buy an FIC. You need some form of engine management. The stock ECU can't handle more then about 5lbs intercooled.
Return to “Forced Induction”
