[FS] 67 mm TB and other GO Fast part also on E-bay
I have a couple of item on E-bay as indicate below. Check them out....
- 67 mm CZT TB : Item number: 280248351931
- 9 lbs miller Flywheel : Item number: 280248340153
- 255 L walbro : Item number: 280248378459
- KL31 ECU : Item number: 280248331128
- KL36 ECU : Item number: 280248334585
- UNDER Drive pulley with belts... : Item number: 280248371139
More to come:
** KLZE curve neck mani lightly ported ***
** Hot Shot TURBO header - "LIKE NEW" ***
** DOHC 24 Valve lettering valve cover **
** KLZE Thermo insolator ***
** Coil blaster 2 with msd 6a and cap tap for it. **
** KLZE distributor **
** MX3 guage face cover in brush aluminum finish **
93 MX3 GS with a KLZE no rust and complete... $600 firm
I replace head gasket but think I didn't do the timing
correctly. Heads have been checked and shave to level by
local machine shop, new head gasket, new valve cover gasket
has I think 120+ K on body but of course less than that on
engine. I just can't get it to start not sure from the timing or
the security it currently has. In any case lost interest. If you
are close by, you can pick it up for CHEEEEEP..
** OTHERS to come **
Let me know if you need anything ELSE ....
More to come:
93 Purple X3 GS SE ... More Mod to come...
- ElectricEnergy
Re: [FS] 67 mm TB and other GO Fast part also on E-bay
I'm interested in a number of your items. Can you ship to Canada?
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
V8KOMX3: No pics but it is in very good condition. Just lost interest in it. Front bumper is off now and on jax stand.
Electricenergy: If you are willing to pay for shipping, I'll look into it depending on what you need. PM me your address and parts you need and we'll go from there.... Thanks.
$600 for the car. with ZE, thats a steal!
Then either buy it or keep your comments to yourself. Gee why did I just say that????
Is the 67mm TB that you are selling, a direct bolt-on into a K8 MX3 ?
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
If you can get me some pics of the car I would be very interested your only 400 miles away from my place in south dakota and 650 miles away from my place in wyoming.
Teal 1993 MX3GSZE
OK.. I will do it this weekend. Just will have much clutter around it but over all it is in good shape. Thanks.
